- Past hour
Hi Archie, On Phantom, If I try and add a fixture via [Setup] [add fixtures], I can only enter fixture numbers starting at 101. If I delete a dimmer channel first, then I can enter the fixture number of the deleted dimmer channel. which makes sense, so will do this first. I have changed the flash button to select, as you described. I will try on the real desk, once at the venue. Thanks for your help. Paul PS. With all the desks you own, you must have a big garage! - Last week
Hi @Muller Light, You can patch your RGBW fixture onto the faders by assigning it a fixture number of 1-48 (or 1-96 if using a Solution XL), and the fader will control the intensity. To control colour, the fixture must be selected. Solution consoles don't automatically select fixtures when channel faders are raised like FLX and FLX S consoles do, so you would need to select it manually. You can turn the channel flash buttons below the faders into fixture select buttons via SPECIAL -> Channel button mode -> Select. This replicates the behaviour of the select buttons on FLX and FLX S - tap to select, tap again to deselect. The button's yellow LED will illuminate when that fixture is currently selected. Once the fixture is selected, you can control the colour in the same way as fixtures that are on the MFKs. Hope this helps, Archie -
So, if I have a light that is, say, RGBW + dimmer level, how do I setup the solution to have it as fixture number 1, so I can control the level with the fader and the colour with the MFKs and wheels? -
That’s great news! Thanks for confirming and no shame in asking here!
Just been at the theatre doing a check…. Yes, it’s the power supply! You’re right, nothing wrong with the dimmer. Scratch this post. many thanks, Zulu
kgallen started following Betapack dimmer packed up.
Betapack 1 are solidly reliable so this is surprising to have a ‘total dead’. There is no overall fuse in the unit as they can be wired single or 3 phase delta or star. Are you sure your supply is ok? Check your supply MCB/RCD first if you haven’t. Does an Act 6 work in the same supply socket? The Betapack power led should be lit (red or green depending on analogue desk supply polarity). None of the channel fuse neons should be lit. Can you investigate more and provide more info?
Hi, I have 24 channels of dimming, using 3 x Strand Act 6 dimmer packs, and 1 x zero88 beta pack. See photo. the Betapack didn’t power up tonight when switched on. No life at all. I’m hoping it’s just a fuse. Anyone got a manual, or instructions on how to check/fix this? many thanks, Zulu.
Don’t apologise - life gets in the way sometimes! I hope they’ve managed to sort the intermittent fault out. My JesterML had a ribbon cable that looked like the legs of the components on the front panel had pierced part of it. On the Blue Room, I assisted someone else identifying an issue with their front panel on a Jester 24/48. Their ribbon cable was pierced too. Seems like it might be a common thing? But not sure. Possibly could be solved by carefully cutting the component leg just below the solder joint while leaving a little bit of leg left, shortening the spike. That way the ribbon cable hopefully won’t suffer. -
Should have updated with results. Sorry. I replaced the fader and found that the ribbon cable was missing clips. Made sure the ribbon connectors were properly in (although not clipped) before closing up. The fault seemed fixed although it did re-occur. Lent it to a local AmDram with a warning about the fault. Even with the fault the monitor shows the correct information so they were happy enough and after the show they bought the desk for what I'd spent on it (no charge for time). It did go on to have issues with faders (also intermittent). Still think it's the ribbon cable. The AmDram's tech's dad is an electronics engineer so left it with them. Not heard since. -
Update time! The issue has been coming back intermittently. Rather late, but tonight I have just replaced the ribbon cable between the processor board and front panel with one which came out of my spare Juggler (has the same FC-26P connector). Will be monitoring how it does over this week and if the buggy LCD issue arises again. Will post progress on the issue. -
Hi Zulu, No worries - fantastic to hear everything’s working as intended now. Best of luck with your show! Archie
Hi, Archie. thanks for the advice on this . . . It worked as described on the actual rig, and we are now good to go for our upcoming show. many thanks, Zulu
Thanks, that’s useful.
Archie D started following Move on Dark glitch and fixture description
Hi @Petera, The ADJ Jolt 300 is available in the ZerOS Fixture Library on the console, therefore you won't need to match the channels to another fixture in the library. Archie
Hi Brian, When a playback with values stored is raised or active while recording a cue, those values are stored into that newly recorded cue. You can circumvent this by disabling Smart Tag in the Record / Update Options window (tap RECORD or UPDATE, then tap again to exit - selection will be stored). When Smart Tag is disabled, values coming from other active playbacks will not be recorded in, preventing slip-ups. The source options at the top of the Update Options window are effectively a way of telling the console what things you want to update in a single operation. It can be added to via syntax, e.g. UPDATE (the cue I am currently in is automatically in the source options), AND 2 (adds cue 2 to the source options, to specify cues from other playbacks at the same time use Playback Number/Cue Number). This means the console will be updating both the cue I am currently in as well as cue 2 with the desired 'Remove' operation. You can tap various items in the source options area to exclude them or add them, indicated with red and blue stripes. Correct - the values would be stored inside the recorded cue within the main stack, therefore they need to be removed from the cue. To remove a fixture entirely from a cue, you can follow my listed steps in my earlier post but leaving out the un-tagging of Intensity. Go into the cue, simply home the fixture(s) to tag all parameters and then remove from the cue via Update. I hope this helps - if you have any queries or require further explanation feel free to ask. Archie
Hi Zulu, No worries, glad to hear the solution worked on Phantom ZerOS for you. To 'fix' an individual cue, repeating the steps listed would work perfectly. However, if you have a range of cues together which all have the same problem, you could attempt using Track Forwards in the tracking options along with 'Remove' within the Update Window, but be aware of potential blocked cues. If the values that cause the movement and colour change during the fadeout are tracked through to following cues, then Track Forwards will work alongside 'Remove'. You can alternatively use Cue Only in the tracking options within the Update Window and simply use syntax (UPDATE 3 THRU 7), which would apply the 'Remove' to all of those cues for tagged parameters. As the issue you're facing is rooted from information stored in cues, the cues themselves must be updated to remove that information. If you have any other questions, please feel free to ask. Archie
I’m a relative newbie and still getting my head around a few of the concepts (remove being one of them). A few days ago I managed to accidentally record another playback into my main cue stack while I was editing. I’d recently saved the show so the quickest option for me was to reload a previous save as it was in the middle of a rehearsal. I now realise how I could have relatively quickly removed the offending fixtures from that explanation. I vaguely recall however seeing seeing source options at the top of the update / record screen so I’m now also wondering if that can be used in a similar way to remove the incorrect playback as a source? Is that possible for the next time I make a similar mistake? edit, Thinking about it though I’m assuming the answer must be ‘no’ as once I’ve updated the main cue stack that becomes the source rather than the playback so I’d have to resort to removing the relevant fixtures.
Hi, Archie thanks for your consideration on this. I’ve just tied it on Phantom, at home, and it seems to work just as you described. Although I can’t really test it until I apply it at the theatre. (no lighting rig at home!) as this problem exists on several cues in my stack which use the moving lights, must I apply this solution to each following cue? Or is there a global solution for the entire Playback? (I notice your recommendation includes ensuring “This Cue Only” is enabled. thanks again, Zulu.
Hi @Zulu, It sounds as if the cue in which your fixtures fade out have position and colour information too. To let these fixtures fade out without any movement or colour changes, we need to remove that information from that cue. First, save a copy of your showfile so you can revert to it if needed (Z/Shift -> Save Show). Now select your problematic cue (the one to fade out the fixtures) and tap GO to proceed into that cue. Select your moving fixtures, then tap the Home icon (top left of the internal touchscreen). This homes & tags all parameters for the selected fixture(s). Now, we want to un-tag only the Intensity parameter so that the intensity of the fixtures still go to zero (e.g. that information is preserved), instead of previous values tracking through. To do this, tap the Z/Shift key, then tap 'Intensity' above the first encoder wheel - it should switch to have a dark background. That parameter is now un-tagged. Now tap the UPDATE key (you may have to hold it for the Update Window to appear on the internal touchscreen, this behaviour can be adjusted in SETUP -> Settings -> Record & Update), ensure 'Remove' has a red stripe (enabled) and Smart Tag has a blue stripe (disabled). Also make sure that 'Cue Only' has a red stripe so that we are only dealing with and affecting this cue. Tap your Master GO button to submit the update. You should now find that the fixtures fade out without changing position and colour. If you have any questions feel free to ask. Archie
Hi. I’m using a couple of moving lights in various cues, for my theatre style cue stack on the master playback. move on Dark is set, and the light does as expected when entering the cue. But….. when moving to the next cue which does not need the moving lights, the moving lights visibly move and change colour during the fade-out. Not the desired effect, as I’m just wanting it to fade before moving. any thoughts? many thanks, Zulu
Archie D started following Solution desk servicing
Denis Twomey joined the community
Many thanks Archie, I'm happy to have a go but my committee are a bit less enthusiastic. I tried White Light but had trouble creating an account. I confirmed my email but get a never-ending spinny circle when I log in. Will try again next week but you've given me a backup at least.
Hi Simon, It is extremely unfortunate that Ian passed away, he is definitely missed. Regarding the wheels - there is a tiny PCB on each wheel held by four plastic clips (two latch over the PCB and two stick up through holes on the PCB). If this PCB comes out of those clips and slides out slightly, the contacts don't meet the wheel and so the wheel's movements are not read correctly. If you don't get anywhere with White Light as kgallen has suggested, and are confident with opening your Solution up (the front panel along with the palm-rest hinges up from the base to an extent) then it may be worth checking those PCBs. If all PCBs are seated correctly and the wheels still do not respond correctly, it would be worth looking into spares. Hope this helps.
Hi Edward, Apologies for the delay, things have been rather busy this end. Thank you for your advice - when things have calmed down a bit I will have a look into the BIOS instructions, thank you for the link. I'll let you know the outcome. Many thanks again, Archie
