Thomas Haaser Posted December 10, 2007 Report Share Posted December 10, 2007 Hallo, I hope in the new release the function the MFG button Drive & Speed & go on. I think the function must: select submaster or memory in the window press the MFG button and change value and save in the select submaster or memory. or how must the function. Bye, Thomas Quote Link to comment Share on other sites More sharing options...
K-Nine Posted December 10, 2007 Report Share Posted December 10, 2007 If you are referring to the chase modifier keys on Special Page 1 (Direction, Brightness Attack, Drive, Speed etc.) then these are designed for temporary live adjustment of chases as they are running. If you wish to edit a chase and save the updated modifiers then this should be done via the Memory Setup Window or the Submaster Setup Window, as appropriate. Quote K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace Link to comment Share on other sites More sharing options...
Thomas Haaser Posted December 10, 2007 Author Report Share Posted December 10, 2007 ok, the is it!! I wish in the Submaster/Memorysetup (default) a optionswitch Special Page 1 yes or no. Not all live Chase is good change the value. Quote Link to comment Share on other sites More sharing options...
