Carl Ehrhardt Posted October 26, 2010 Report Share Posted October 26, 2010 Hi Peter Do you have any information about the new version 6.0? Do you already know when it is going to be released? Greetings from snowy Switzerland Carl Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
Jon Hole Posted October 26, 2010 Report Share Posted October 26, 2010 Hi Carl, I'll be uploading information in the next few hours, and the software is already available online - click here. (The software is the same release for ORB, Leap Frog 48 + 96, and Frog 2). Hope this helps, Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Carl Ehrhardt Posted October 26, 2010 Author Report Share Posted October 26, 2010 Hi Jon, Wow that's fast Thank you. Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
chw Posted October 26, 2010 Report Share Posted October 26, 2010 looks good, but I still miss a learn feature for different "beats" for chases running on submasters. Quote Link to comment Share on other sites More sharing options...
pierotec Posted October 26, 2010 Report Share Posted October 26, 2010 Hi, this release is compatible with all frog2, also older hardware? Thanks Piero Quote Link to comment Share on other sites More sharing options...
pierotec Posted October 26, 2010 Report Share Posted October 26, 2010 is alredy available the application ipad monitor? ciao piero Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted October 27, 2010 Report Share Posted October 27, 2010 We've tested it on both old and new hardware for the Frog 2. An update to the ZerOS remote app is currently going through Apple's app submission process. This same app will now give you the additional iPad remote desktop features. And chw, you can still set a chase to accept a manual 'beat' that the desk will then learn, by double clicking in the comments column and changing the options in there. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
chw Posted October 27, 2010 Report Share Posted October 27, 2010 Hi Jon, Thanks for the reply. I was thinking about something like pressing the beat button and use the submaster flash buttons to enter the beat. Using mouse and keyboards is just "to slow" for me and you have to enter a bpm value - press a button with your finger is much easier. Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted October 27, 2010 Report Share Posted October 27, 2010 I was thinking about something like pressing the beat button and use the submaster flash buttons to enter the beat ... press a button with your finger is much easier. Yep - you can do this. You just need to change the chase drive to 'beat' instead of 'auto' and then the desk will learn the speed you tap the button at, instead of using the BPM speed. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
chw Posted October 28, 2010 Report Share Posted October 28, 2010 Hi Jon, Thanks for the reply, but then its for all chases running on all submasters or if I use the step button of the memory section for all chases running in the memory stack. Or is there something I didn't see? Example: Chase A Submaster 1 Chase B Submaster 2 Chase C Submaster 3 Chase.... All of them are set to "beat" If I setp in a beat all of them are running with the same speed. I think it could now be useful to be able to "step in" individual "beats" for all those Submaster chases. Maybe you have some par cans in the back, they should change slowly and some moving stuff on stage that should be faster. For pre-programmed shows it's not so important, but if it is a live performance and the band is not using any kind of set list - for me that feature would be very useful. Unfortunately a lot of those "48 Dimmer channels and 24 Movingheaads" shows I'm doing are like that. Quote Link to comment Share on other sites More sharing options...
