Harry Kerver Posted November 16, 2018 Report Share Posted November 16, 2018 Hello, Yesterday I've updated the latest ZeroOs software for the Orb desk. When I want to program a submaster, it shows the playback directory. According the old manual I have to: Hold SETUP and press the select key above a playback etc. but that doesn't seem to work. I could use some help on this one? Regards, Harry Kerver Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted November 16, 2018 Report Share Posted November 16, 2018 Hi Harry, To program a submaster (which in the new software is referred to as a playback containing a single cue), create your lighting state, tap RECORD, and then tap the playback button to store to. SHIFT + FADER FUNCT will open your Faders Window to show you what they're currently doing. SHIFT + SUB will open your Playback directory. It is worth mentioning the SUB and STACK keys in the latest software both have identical functionality. Holding SETUP + tapping a playback's button will enter the playback's settings. You may find the document below useful, which goes through the software changes... http://support.zero88.com/988876801 Hope that helps, if you have any queries just let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Mihail Sabevski Posted December 31, 2018 Report Share Posted December 31, 2018 Hi Edward, Thank you very much for the prompt reply and for the support. I wish you a very pleasant, healthy and fruitful New Year! We will be hearing after a New Year if I have new questions. Regards, Mihail Sabevski Quote Link to comment Share on other sites More sharing options...
