AlexSky Posted October 13, 2020 Report Share Posted October 13, 2020 Hi everyone. After updating the ORB XF console, there were problems with displaying on the LSD 2x control wheels of any devices with several color values, gobo, etc. I had to roll back to 7.9.7, everything works there... Devices in which no values were displayed: Briteq BT-575S, Briteq BT-575W, Briteq Led Mega Beam, Briteq Led Pixel bar RGB. It is also unclear how in 7.9.8 to create a new device using Fixture Type Editor with a resolution of .zlbr Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 14, 2020 Report Share Posted October 14, 2020 Hi Alex, 16 hours ago, AlexSky said: Devices in which no values were displayed: Briteq BT-575S, Briteq BT-575W, Briteq Led Mega Beam, Briteq Led Pixel bar RGB. I have patched a BriteQ BT-575S into Phantom ORB XF running ZerOS 7.9.8. Selecting the fixture and tapping COLOUR, shows me "Colour Wheel" and "Colour Wheel Mode" parameters on encoders 1 and 2. Tap BEAM, and gobo controls are shown on encoders 2 and 3, tap BEAM again and I can page through. What are you seeing when doing this? Are the encoders remaining blank (blue)? Is the "Intensity" display visible above the intensity wheel? Have you held SETUP and adjusted the LCD contrast? 16 hours ago, AlexSky said: It is also unclear how in 7.9.8 to create a new device using Fixture Type Editor with a resolution of .zlbr The Fixture Editor software still allows you to create fixtures in the .ift file format, which can be loaded into ZerOS 7.9.8. These custom fixture files will therefore be displayed in red in Add Fixtures and the Fixture Schedule, to indicate the fixtures are not from the library. If you would like fixtures adding to the library which are missing, please email the fixture's manual to us at fixturesupport@zero88.com, and we'll be able to get this added to the library for the next release. I hope this helps, if you have any questions let us know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
AlexSky Posted October 14, 2020 Author Report Share Posted October 14, 2020 4 hours ago, Edward- Z88 said: I have patched a BriteQ BT-575S into Phantom ORB XF running ZerOS 7.9.8. Selecting the fixture and tapping COLOUR, shows me "Colour Wheel" and "Colour Wheel Mode" parameters on encoders 1 and 2. Tap BEAM, and gobo controls are shown on encoders 2 and 3, tap BEAM again and I can page through. What are you seeing when doing this? Are the encoders remaining blank (blue)? Is the "Intensity" display visible above the intensity wheel? Have you held SETUP and adjusted the LCD contrast? Yes, I did so too, and in ORB XF encoders 2 and 3 remaining blank (blue), and "intensity" and 1 encoder, work. And in Phantom ORB XF everything works great. The contrast LSD checked all right. I also tried other fixtures.. also do not work on the console. Alexander Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 14, 2020 Report Share Posted October 14, 2020 Hi Alexander, 57 minutes ago, AlexSky said: Yes, I did so too, and in ORB XF encoders 2 and 3 remaining blank (blue), and "intensity" and 1 encoder, work. And in Phantom ORB XF everything works great. The contrast LSD checked all right. Thank you for confirming. On ORB XF, if you select a fixture, and encoders 2 and 3 remain blank, please view the "Wheels" desktop on the external monitor. Are the parameters displayed on encoders 2 and 3 here? If you use the physical encoders, do the values change on the external monitor? Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
AlexSky Posted October 15, 2020 Author Report Share Posted October 15, 2020 20 hours ago, Edward- Z88 said: Thank you for confirming. On ORB XF, if you select a fixture, and encoders 2 and 3 remain blank, please view the "Wheels" desktop on the external monitor. Are the parameters displayed on encoders 2 and 3 here? If you use the physical encoders, do the values change on the external monitor? I checked... Yes, the external monitor displays and changes values... And on the console there is no... Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 15, 2020 Report Share Posted October 15, 2020 Hi Alex, After recording a cue with intensity information stored, please tap on the "Fade Up" or "Fade Down" fields in the Cue list window. Do the encoders display fade and delay times correctly? Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
AlexSky Posted October 15, 2020 Author Report Share Posted October 15, 2020 1 hour ago, Edward- Z88 said: Hi Alex, After recording a cue with intensity information stored, please tap on the "Fade Up" or "Fade Down" fields in the Cue list window. Do the encoders display fade and delay times correctly? Edward Checked... same values change but are not displayed on the console LSD. Quote Link to comment Share on other sites More sharing options...
AlexSky Posted October 15, 2020 Author Report Share Posted October 15, 2020 As I understood on the ORB XF console in version 7.9.8. the LSD screen does not work, and in version 7.9.7 everything works perfectly. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 16, 2020 Report Share Posted October 16, 2020 Hi Alex, On 10/15/2020 at 1:04 PM, AlexSky said: Checked... same values change but are not displayed on the console LSD. On 10/15/2020 at 1:43 PM, AlexSky said: As I understood on the ORB XF console in version 7.9.8. the LSD screen does not work, and in version 7.9.7 everything works perfectly. Thanks for all your information on this. We have found an issue that is affecting the encoder displays on some ORB series consoles. We will look to release a bug fix for this as soon as possible. In the meantime if you wish to roll back to ZerOS 7.9.7, please see the link below... https://zero88.com/zeros#legacy If you have any questions please let us know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
AlexSky Posted October 19, 2020 Author Report Share Posted October 19, 2020 Thanks, I downgrade to the version of ZeroOS 7.9.7. I will follow the updates)) Alex Quote Link to comment Share on other sites More sharing options...
Gingersteve91 Posted October 20, 2020 Report Share Posted October 20, 2020 On 10/19/2020 at 1:00 PM, AlexSky said: Thanks, I downgrade to the version of ZeroOS 7.9.7. I will follow the updates)) Alex Thanks for posting this Alex, as a fellow ORB operator I will hold off upgrading for now. 7.9.7 question for you... When using our MAC 250s the DMX parameters for Pan & Tilt show up as 100000 values as opposed to 0-255 or 0-100%. Have you experienced this for any of your moving stock aswel, If so have you managed to get it to display the DMX value? Quote Link to comment Share on other sites More sharing options...
Gingersteve91 Posted October 20, 2020 Report Share Posted October 20, 2020 On 10/16/2020 at 1:49 PM, Edward- Z88 said: We have found an issue that is affecting the encoder displays on some ORB series consoles. We will look to release a bug fix for this as soon as possible. In the meantime if you wish to roll back to ZerOS 7.9.7, please see the link below... https://zero88.com/zeros#legacy If you have any questions please let us know. Edward Hi Edward, Can I down grade my Phantom ZerOS for PC using the legacy file? I'm doing some work from home and would like my Phantom software to be the same as our physical Desk. Thanks, Steve Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 20, 2020 Report Share Posted October 20, 2020 Hi Steve, 39 minutes ago, Gingersteve91 said: Thanks for posting this Alex, as a fellow ORB operator I will hold off upgrading for now. Just as a bit of an update, our software team have found and fixed this issue. We will be releasing this fix in the next few weeks. 40 minutes ago, Gingersteve91 said: 7.9.7 question for you... When using our MAC 250s the DMX parameters for Pan & Tilt show up as 100000 values as opposed to 0-255 or 0-100%. Have you experienced this for any of your moving stock aswel, If so have you managed to get it to display the DMX value? Encoder wheel displays will show the DMX value being sent to the fixture. If you are seeing a value of 0-65535, this means this is a 16bit parameter, and it therefore uses a pair of DMX channels for control, rather than a single DMX channel for 8bit parameters, with a range from 0-255. 37 minutes ago, Gingersteve91 said: Can I down grade my Phantom ZerOS for PC using the legacy file? I'm doing some work from home and would like my Phantom software to be the same as our physical Desk. Yes you can. The ZerOS 7.9.7 download available below contains the release notes, console software, and Phantom ZerOS... https://zero88.com/storage/downloads/51a59da7-2286-438b-8458-925b3a9f49cb/ZerOS-7.9.7.zip I hope this helps, if you have any questions let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Gingersteve91 Posted October 21, 2020 Report Share Posted October 21, 2020 8 hours ago, Edward- Z88 said: Hi Steve, Just as a bit of an update, our software team have found and fixed this issue. We will be releasing this fix in the next few weeks. Great news thanks for the update. 8 hours ago, Edward- Z88 said: Encoder wheel displays will show the DMX value being sent to the fixture. If you are seeing a value of 0-65535, this means this is a 16bit parameter, and it therefore uses a pair of DMX channels for control, rather than a single DMX channel for 8bit parameters, with a range from 0-255. Ah ofcourse that makes sense sorry me being an idiot! This only changed for us a few updates ago, previously they always showed as 0-255... I used to use 3 digit reference points when plotting new pallets for shows so it threw me a little haha. 8 hours ago, Edward- Z88 said: Yes you can. The ZerOS 7.9.7 download available below contains the release notes, console software, and Phantom ZerOS... https://zero88.com/storage/downloads/51a59da7-2286-438b-8458-925b3a9f49cb/ZerOS-7.9.7.zip I hope this helps, if you have any questions let me know. Thats great thank you. Steve. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted October 21, 2020 Report Share Posted October 21, 2020 Hi Steve, 7 hours ago, Gingersteve91 said: I used to use 3 digit reference points when plotting new pallets for shows so it threw me a little haha. To get back to an 8bit value, divide the 16bit value by 256. Cheers, Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
el gordo Posted December 1, 2020 Report Share Posted December 1, 2020 Hi everyone, exact same issue here. Had a demo of a Chauvet Maverick Silens 2 Profile today and had to use the ZerOs app to see what I'm doing on the desks encoders. Quite annoying. I couldn't figure out a way to separately load the latest fixture library on version 7.9.7, since the Silens came out in september and isn't included in the 7.9.7 library. In 7.9.8 it is, so I switched back and hope for a bugfix update very soon. Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 2, 2020 Report Share Posted December 2, 2020 Hi @el gordo, Welcome to the Zero 88 Forum. 11 hours ago, el gordo said: exact same issue here. Really sorry to hear you have come across this issue on Orb as well. 11 hours ago, el gordo said: had to use the ZerOs app to see what I'm doing on the desks encoders. To view the functionality of the Orb encoders, you can view the "Wheels" desktop on the external monitor. 11 hours ago, el gordo said: I couldn't figure out a way to separately load the latest fixture library on version 7.9.7 The latest full library that was compatible with ZerOS 7.9.7 was GFT40. We now use a new format for our fixture libraries (ZLBR), which will not be compatible with ZerOS 7.9.7 and earlier. 11 hours ago, el gordo said: In 7.9.8 it is, so I switched back and hope for a bugfix update very soon. Our software team have already fixed the issue, which will be included in ZerOS 7.9.9, currently scheduled for release by the end of the year. If you would like access to a pre-release version of software containing the fix, please send me an email. If you have any questions let me know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Caffrey Posted December 5, 2020 Report Share Posted December 5, 2020 I've just upgraded to 7.9.8 on my Leap Frog 48/96 and now can't use the Stairville MH-110 Wash 7x10 LED as the "Intensity" scroller is missing... I can pan and tilt; just can't turn the lights on I'm going live with our Christmas Panto rehearsals on Monday, so any news on 7.9.9? or should I downgrade back to 7.9.6 to get the fixture library back to a known state. By the way, the Stairville HL-x9 Quad is completely missing from the 7.9.8 update but was in the 7.9.6 so I've presumed that the HL-x18 has the same settings... Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 5, 2020 Report Share Posted December 5, 2020 Hi Caffrey, Welcome to the Zero 88 Forum. 33 minutes ago, Caffrey said: I'm going live with our Christmas Panto rehearsals on Monday, so any news on 7.9.9? or should I downgrade back to 7.9.6 to get the fixture library back to a known state. We are hoping to release a “Release Candidate” of ZerOS 7.9.9 next week to our forum beta testers. All being well with that, we will then be able to release ZerOS 7.9.9 officially. Therefore if you need to access the Intensity wheel for these fixtures on Monday, I’d recommend rolling your software back to ZerOS 7.9.7. ZerOS 7.9.7 can be downloaded from the link below... https://zero88.com/zeros#legacy 36 minutes ago, Caffrey said: By the way, the Stairville HL-x9 Quad is completely missing from the 7.9.8 update but was in the 7.9.6 Please drop us a link to the missing fixture’s manual to fixturesupport@zero88.com, and we’ll add the fixture to the list to be included in a future fixture library release. I hope this helps, if you have any questions let us know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 15, 2020 Report Share Posted December 15, 2020 Hello, ZerOS 7.9.9 has now been released... https://zero88.com/zeros#download If you have any questions let us know. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
