Fixtures stuck on
Malvern
After restarting  the desk, hold Shift and press View to display the output window. It seems likely that the affected fixtures will be at 100% but note what colour they are and check the manual here. Then select the Source tab. Hopefully these two actions will give you a clue to what it is that is setting the colour and intensity of the fixtures and you can correct it.
If it doesn't help then try the DMX outputs. Press the Z key, select System Information and then DMX Outputs. Using the address of one of the fixtures locate the values being sent to it make sure they reflect what you are seeing - if not then the fixture may not be patched correctly, have the wrong profile or be operating in the wrong mode. If the intensity and colour values are all zero then the fixtures own settings need checking.
Finally, try recording new default values for the fixtures. See the manual here.
Bonjour,
Je pense que tu as une cue active avec ces projecteurs. Pour arrêter toutes les cues et voir si tu retrouves ton état original, il faut maintenir Clear enfoncé et appuyer sur le Bouton MFF.
Pour Arrêter une cue, il faut maintenir clear enfoncé et appuyé sur le bouton flash du playback dans laquelle elle se trouve.
Dis-moi si en faisant ça, le soucis que tu as persiste.
  • Edward Z88 changed the title to Fixtures stuck on
