Fixture library
Tom1234
Hi all
I have been having some issues adding new fixtures to my Jester ML24, and so was wanting to buy a cheap Par Can -Equinox MaxiPar Quad LED Par Can to test a few things out. However when looking on the fixture library, I realise that this light is not on the list. I there a way of adding it?
Many thanks
Tom
Hi @Tom1234
Yes there is - your best option is to email a link to your fixture's English manual to fixturesupport@zero88.com. We will then be able to provide you with a fixture file for you to load into your Jester ML24.
It is worth noting that if your fixture has a simple mode such as 3-channel RGB, you will be able to use the simple LED fixtures that are included in the Jester ML24. These can be found in Assign Fixtures -> Add Fixtures -> Fixture Library -> Standard Fixtures -> Conventionals
Hi Tom,
11 hours ago, Tom1234 said:
is there a way to see how many channels a fixture is taking up from the desk or would one have to read that from the light display screen.
When patching fixtures into the Jester, the number of channels used by a fixture is usually displayed at the end of the fixture's name. For example "12Ch".
