Chilli Pro
Relay Cards
Chilli Pro can have dimmer channels replaced with relays, by fitting a relay card. Relay cards are 4 channel boards, which can be used to replace blocks of 4 dimming channels with relays. These relays can then be controlled by DMX, to switch the connected load.
Relay cards are available as a primary and secondary board. The primary card includes a PSU, and so a single primary card can be added to give 4 relay channels. Additional secondary cards can then be added and powered off the primary, to give more relays.
Chilli Pro 12 can have a single primary card, with a pair of secondary cards powered from the primary, to provide all 12 channels as relays.
Chilli Pro 24 can have a pair of primary cards, and a pair of secondary cards powered from each primary, to provide all 24 channels as relays.
