DMX Controls
RDM
Select the RDM option from the menu, and press the ENT key. The screen shows the current setting for the dimmer, for example:
< RDM Control >
RDM is On
Use the cursor keys to alter this setting between On and Off, to enable or disable the DMX RDM (Remote Device Management) functionality of the Chilli Dimmer.
RDM Support
The first 5 digits of the part number are used for the Device Model ID., e.g. 01105 (0x0451) for the Chilli Pro 1210.
Supported Parameters:
- DMX_START_ADDRESS,
- SENSOR_DEFINITION,
- SENSOR_VALUE,
- DEVICE_LABEL,
- MANUFACTURER_LABEL,
- DEVICE_MODEL_DESCRIPTION
Sub Devices:
- One per channel
