DMX Controls
Set DMX Patch
PDF
This option allows you to set an individual DMX address (1 - 512) for each channel of the dimmer.
Select the Set DMX Patch option from the menu, and press the ENT key. The screen shows:
The cursor appears in the Channel field. Press the ENT key to move between the Channel and DMX fields, and adjust the values using the numeric keypad or cursor keys.
