Memories
Clear Memories
PDF
Standard Mode
This option allows you to clear all the 12 memories in the dimmer.
Select the Clear Memories option from the Memories menu, and press the ENT key. The screen shows:
Press the ENT key to clear all the memories and any programmed sequences in the dimmer.
The screen returns to the Memories screen.
ChilliNet Mode
This option allows you to clear all the 12 memories for a specified area in the dimmer.
The cursor appears in the Area field. Use the numeric or cursor keys to select the required area number (0-10), then press the ENT key.
Area 0: This is a special case. The dimmer will clear all stored memories for all areas, and all programmed sequences on the dimmer.
Area 1 -10: The dimmer will clear all the stored memories for the selected area, and any programmed sequences for the selected area on the dimmer.
