Memories
Play Memory
Watch this video to find out about playing memories.
Playback Memory
xx
The cursor appears in the memory number field (xx). If a memory is currently being output, then that number is shown in the field.
Use the numeric keypad or cursor keys to select a memory to be output (0 - 12).
Press the ENT key to confirm the memory number selection. The dimmer performs the following:
- Memory Zero - The outputs fade to zero in 3 seconds, and replace any previous memory or sequence being output.
- Programmed Memory - The outputs fade to those in the selected memory in the memory’s fade time, and replace any previous memory or sequence being output.
- Unprogrammed Memory – * is displayed and the outputs do not change.
The screen returns to the Play Memory screen.
Memory Zero is a fixed, non-editable memory, with a fade time of 3 seconds and all channels programmed at 0%.
In standard mode, a dimmer can only play back one memory at a time.
Area: 1
Memory: xx
The cursor is in the Area field. Enter the required area number using the numeric keypad or cursor keys, then press the ENT key.
If the area number is valid, the cursor moves to the Memory field.
If a memory for the selected area is currently being output from the dimmer, then that number is shown.
The dimmer sends out the corresponding Play Memory / Area message onto the network.
If the dimmer has one or more channels assigned to the specified area it performs the following:
- Memory Zero - The outputs fade to zero in 3 seconds, and replace any previous memory or sequence being output for the selected area.
- Programmed Memory - The outputs fade to those in the selected memory in the memories fade time, and replace any previous memory or sequence being output for the selected area.
In ChilliNet mode, a dimmer can only play back one memory per area at a time, but may play back up to ten different memories if they are all in different areas.
