Sequences
Clear Sequence
PDF
This option allows you to clear any of the sequences in the dimmer.
Select the Clear Sequence option from the Sequences menu, and press the ENT key, the screen shows:
Use the numeric keypad or cursor keys to select the required sequence, then press the ENT key, the screen shows:
Press the ENT key. The screen returns to the
Clear Sequence screen.
