Sequences
Sequence Options
PDF
This option allows you to adjust the crossfade and dwell times for the sequences in the dimmer.
These times are global and apply to all three sequences in the dimmer.
Select the Sequence Options option from the Sequences menu, and press the ENT key, the screen shows:
The cursor appears in the X-Fade Time field. Use the numeric keypad or cursor keys to adjust the fade time as required (range 1 - 60 seconds).
Press the ENT key to confirm the crossfade time. The cursor moves to the Dwell Time field.
Use the numeric keypad or cursor keys to adjust the dwell time as required (range 1 - 600 seconds).
Press the ENT key to confirm the dwell time. The cursor moves to the X-Fade Time field.
