Playing Back Cues
Goto Cue
GOTO CUE
Goto cue allows you to jump to a specific cue. On FLX, simply hold down the playback’s Go button. "Goto Cue x/" will be written in the command line, where x is the playback number. You can then type the cue number you wish to go to with the other hand, for example:
Goto Cue 0/5.5
Then release the playback’s GO button, and you will go to that cue. FLX S users can also do this, using the number pad found by pressing Z/Shift
SNAP TO CUE
To snap to a cue ignoring fade times, for example, during a programming session when you want to alter a cue without having to wait for the cue fade to complete, hold Shift and then tap the Go button of the playback you are using. This will snap to the cue, rather than using the fade times. Doing this also won’t allow Auto Triggers to work (useful to jump to a cue without automatically moving onto the next cue).
To snap to a specific cue number, rather than simply the next cue, hold Shift, and then hold Go, and "Snap to Cue x/" will be written in the command line, where x is the playback number. Then release Shift, and with Go held type the cue you wish to snap to, for example:
Snap to Cue 1/20
If this doesn’t work, the playback's settings must have been changed. Ensure the shifted function is set to "Go (Snap)".
