JR Light
JR Light's Achievements
  1. Hello, I have a FLX S48 and some times I have just some RGB LED fixtures to control. I have created some playbacks (cue lists and chases) to control the fixtures. But when I pull down the fader for the playback which is running to 50% for example and turn another playback up, there is a hard change that the fixtures are controlled by the new playback. I would like that if the first playback is setting the fixtures at green and the second playback will turn red on, I would expect that the led fixture will turn yellow. Now there is a hard jump from green to red. How can I solve this? Best regards, Jeroen
  2. Hello Edward, Thank your for your reply. That's a shame. I have multiple types of led fixtures, and multiple types of movingheads and also a few special effects as a laser. There are too less pages on the S48 to hold for all fixtures the playbacks. And then I don't talk about hire extra fixtures... Best regards, Jeroen
  3. Hello Edward, Thank you for your reply. It is working what you suggested but you have to remember which effect/color/beam/position pallets you had applied to create the playback initial. Mayby on the same evening I will remember but after a week I am lost. I hoped there was an easier way. Best regards, Jeroen
  4. Hello, Is it possible to update a playback with more fixtures. For example: I have created a playback as colour fader only for 4 LED fixtures. Or a playback with an effect only for 4 LED fixtures. Now I have 8 LED fixtures. Is it possible to update the playback with the new number of fixtures without starting over again for the new number of fixtures? Best regards, Jeroen
  5. Hello, I'm wondering if it is possible to copy playbacks between showfiles. Or another way to combine showfiles. For example: I have created a few playbacks for my LED fixtures and saved in a showfile. Later I have created a few playbacks for my movingheads and saved in a new showfile without the LED fixtures. So I have 2 showfiles with different fixtures and playbacks. Is there a way to combine these showfiles? Or do I have to create the playbacks again every time when the fixtures changes? Best regards, Jeroen
