Hi. I'm new to the FLX S48, so still getting used to what this system can do, but loving it. I have an external monitor attached and have a question regarding the Cues Playback window.
	When running a playback, the top window displays output of the lamps, as expected. The bottom window shows what cue is running, with fade times and cue stack (if programmed). Also as expected. My question is - when changing to another playback (ie. fade down MFF1 and fade up MFF2), the bottom window doesn't automatically update to the current selected playback. The only way I can change the display is to press and hold view and select the corresponding MFF button. Is there a way/setting so that the cue window automatically updates to the playback that has been selected?
	I hope this makes sense.
	Thanks
	Ciao
	Rob
