TrafficLights3
Everything posted by TrafficLights3
  1. Yep! I was blown away too
  2. Thanks everyone for your help on this, after digging through a good few training webinars on YouTube, I came across the simplest answer - offset, specifically how the offset fans across fixtures. You can change this behaviour by holding setup and tapping effects. I set my shift click to be 'fan first' (Also experimented with the other fan options for different effects) then selected my fixtures, hit chase, held shift and span the encoder wheel to fan the offset of the effect until the chase matched up on all battens. Worked super nicely and certainly opens up some more interesting possibilities for programming Battens Chase LQ.mp4
  3. I have some pixel batten fixtures. When I run a chase effect across a fixture it chases across those pixels. When I run the effect across multiple fixtures, it will chase across them all in order. I’d like for all the battens to pixel chase at the same time as a group. I thought it could be something to do with the offset of the effect, however when I select ‘offset as group’ it ignores the pixels and treats each batten as a single light source. I’ve attached a video of how it works currently and an edited video of how I want it to be able to work. How it works now: https://youtu.be/gVSUg7lTL2w How I want it to work: https://youtu.be/qIHcmw-siQs Is there something I’m missing? Thanks!
