Hi,
	I already did a post on reddit but it didnt get me any further... I have the problem that my LED fixtures (in this case some ROXX eShow TW+ and SGM P5s) switch back to RGB Values 255,255,255 when the trigger release threshold is triggered. You can see it in the Video attached to the reddit post.
	I recreated the whole thing in PhantomZerOS and brought it down to a simple one fixture, one cue setup after a factory default but cant still fade a color cue out without a flash to white at the end.
	I reset the desk completely to factory defaults.
	one fixture, one cue with color red.
	cue fade times (the play/pause button) are all set to zero.
	global fade times and defaults are also on zero (setup->defaults->default cue times)
	I set the home and default values of the one fixture to color 0,0,0 (selecting the channel/fixture set the three color rotaries to 0, make sure they're highlighted blue->Update->home with bulp icon->home and then the same with default.
	Still, my created cue (or a new one based on the set defaults) with just the color red works and goes to 255,255,255 when it reaches the trigger/release level. I can see it in the DMX Output window by pressing Z Button.
	If I got it right, if those were the defaults, they would show up in yellow in the output, but they're shown blue.
	Where do those values come from?
	I also tried editing the default values via the fixture editor on the console, also without the desired effect.
	I just want to fade simple color cues with different faders without any flash(fast or slow) to white below trigger/release level.
	Setting the trigger/release to 0 doesnmt work either.
	Please help! I went through the documentation, videos and reddit. I spend many hours, what am I doing wrong here with such a simple cue?
