Hello there Sir.
Good Day, Well Actually Regarding To What You Are Saying That I have To Check The Smart Tag. I Don't Even Know Where Sir Is that Could Be Located As I Say I Put on A Sub master Is The  Slide One the Moving Head And In the Second Slide i Put The  Dimmer Pack For Parcan, but The problem Is When You Slide Up The Sub Master just Only for Moving Head It Work Fine But If I Try To Slide Up Also the Slide For Dimmer Pack for parcan Its Just The Moving Head Will Reset And To O So That I Don't Know Where Did I Go Wrong Or may be There Is Separate Bank Just Only For  Dimmer Pack..?? Is It Correct Co'z Until now Still The Same problem I Encounter, Which is better Sir. I'll Just Put The Moving From Slide One And The Other Slide Far From The Moving Head Will BE The Dimmer PAck. 1 Last Question Sir. Where Can I Find That What You Are Telling me is About The Smart Tag So I Can See If That Is On Or Not??
Pls. Reply Immediatelly And Thank You very Much.. God Bless.
Jezrael
