WeirdProfessor
WeirdProfessor's Achievements
Apprentice
Apprentice (3/14)
  1. Hi guys I'm using a Leapfrog96. Had a show the other night where I used all 96 faders, but needed six more. In the 96 channels, six of them was front lights, so I recorded them on a submaster and thought I could just repatch and change the front faders to the ones I needed. But when I'd patched them, the submaster recording didn't do anything. When I press "Program", doesn't the desk record the current dmx-addresses? didn't expect it to care which fader I used.. Bo, Scenelys.dk
  2. Hi guys Have just been testing the new software release 4.4 - ever since PLASA I've been looking forward to test the Effects Window. Why do all values follow each other: An example: Pan and Tilt can't have different values, even if only Pan is tagged, the Tilt values get the same values. This is true for every two or more parameters as far as I can see. That makes no sense to me. And it wouldn't hurt if the "tag"-toggle was bigger for touch screen use. I personally liked the small text size in the MFK-display. Could you add a text size changer in the setup? When I use the arrows for browsing colour and effect palette windows, e.g. when I'm rearranging the palettes, the cursor stucks in the "Palette"/"Colour Picker"-buttons in the Color-palettes and stucks in the "Effects Window"-button. Unless I press the touch screen, I can't figure out how to get down to the palettes again. Do you have a hint, or is this not intended? That's it for now. I'll return I stumple upon anything. Bo, Scenelys.dk
  3. I'm adding fixtures to my MFKs 1-5: Wish to create approx. the same setup on my MFK as in real life. Have got the dmx addresses: 97, 125, 153, 181 and 209 First fixture | 97 | _ | _ | _ | _ | Next fixture | 97 | _ | _ | _ | 125 | Everything's fine here, but when I add number 153 at the second MFK (after 97), 153 and 125 swaps position: | 97 | 125 | _ | _ | 153 | This seems kind of odd. I was able to solve the issue by editting the MFK's in Edit Fixtures afterwards.
  4. I'm in Setup, and a remote client is connected. Then I toggle Enable Security to yes, the desk crashes. Black screen with a white cursor cross. I've attached the debug.dat file. By the way, I couldn't upload .dat-files - I was not granted permission to upload that file type. So I renamed the file type to .txt debug.txt
  5. EFFECT+HOME was exactly the combination I was looking for! Seems to work in PhantomFrog Thx a lot! How about the clear in macro thing? is that possible?
  6. Hi guys I'm running e.g. moving effects from the effects pallette, but how do I release the effect without pressing "clear"? And is it possible (in a moving effect) to gently and nicely ending up at the last position I chose from the position pallette? I tried setting up a macro, but is it impossible to use "clear" in a macro? thx Bo
  7. Hi there I wish to be able to control gobo rotation on a submaster fader. No problem, I program the gobo rotation to the submaster, go to the submaster setup and mark 'Beamshape' in the 'Submaster Controls...' However my Clay Paky Alpha Spot 575 HPE's have gobo indexing at 0-127 of the gobo rotation channel and rotation from 128-255. As far as I can see, I can only set the top interval (e.g. 0-60%), but not an interval like (50%-100%). Do you have a solution or is it a possible new feature? Looking forward to seeing you at PLASA. Bo, Scenelys.dk
