Heppu Posted December 19, 2004 Report Posted December 19, 2004 Hi I am a new user from sweden and wondering if it is possible to have the desk in partial mode and then have 2 chases runing at the same time. for example one with their position and then on with the intensity so you can do a flashing movement? ask me if you dont understans i am not very good at english. With regards William wigforss
Laubfrosch Posted December 20, 2004 Report Posted December 20, 2004 Hi Heppy, Yes that´s possible! Like you wrote the desk has to be in partial mode. Please keep in mind that the Frogs always record the brightness values. In your special case: Before pressing program for the first "moving" step turn down the brightness to zero. Then press and hold "Position" + Program(without hold!!!*:-) ) Now go on with your chase ...... The brightness chase has to be programmed like the position chase. cheers Sven Sven Paulsen Klangfarbe Vienna
Heppu Posted December 20, 2004 Author Report Posted December 20, 2004 thanks alot sven i will try it at hristmas eve when im gonna prgoam the show im running. with regards william
