Martin Posted January 5, 2005 Report Posted January 5, 2005 My question is, is it posiible to make the palettes so only some fixture3s react on? i want that fx gobo palettet 1-10 involves All fixtures, but 11-20 only involves some of hte fixtures and the other fixtures arent doing anything if i pres the 13, even when they ar all thosen... Hope you understand Move while dark! -> GOGOGO! Thank you Zero for the FR 5402
K-Nine Posted January 5, 2005 Report Posted January 5, 2005 Ensure that the desk is in partial mode. Only tag those fixtures you want in the palette. Note that when you output a palette - only the selected fixtures which are programmed in the palette will change to their programmed values. For example: Set fixtures 1-6 to red and record them into colour palette 1. Select all fixtures (eg 1-12) and home the colour - all fixtures go to white. Select fixtures 1-3 and output colour palette 1 - fixture 1-3 only go to red; other fixtures do not change. Select fixtures 7-12 and output colour palette 1 - no change to outputs since fixtures 7-12 are not programmed in that palette. K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Martin Posted January 5, 2005 Author Report Posted January 5, 2005 So if fixture 1-12 is thosen (flashin red light) onle the ones that was taggede when i made the pallette wil change ? Move while dark! -> GOGOGO! Thank you Zero for the FR 5402
K-Nine Posted January 5, 2005 Report Posted January 5, 2005 So if fixture 1-12 is thosen (flashin red light) onle the ones that was taggede when i made the pallette wil change ? Assuming you were in partial mode when recording the palette - then that is correct. If a selected fixture (red LED on) is NOT programmed in the palette being output, it's output values will not change. K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
