I have the BULLFROG console and have a strange problem and I trying to duplicate to see when it happens.
The problem is, sometimes the names I have for the POSITION pallets just disappear! The color pallets and everything else are still ok -
Anyone seen this?
Hi Gress,
I read your problems you wrote down.
Can you explain which software release you are using?
Is the program mode set to partial?
If you like you may send me your actual show via PM and I will have a look into your patch (Scrollers), your palettes and subs.
best regards
Sven Paulsen
Klangfarbe Vienna
