I have the Bullfrog console with several moving lights and 4 color scrollers. The color scrollers are patch in as Scroller+1.
I have had this problem a couple times in the past and I think I may have found out when it happens.
The problem is for any color settings I have for my scrollers in a MEMORY, PALLET or SUBMASTER - is seems they wont change to the value I had in the past anymore. I think it happens when I go in and patch in new fixtures.
Of course to correct it, I have to re-edit all my memories, pallets and submasters. It's just the colors for the scrollers and nothing else.
Anyone know whats up?
Assinging new fixtures messes up the pallets in previous software versions, upgrade to version 9.8 and that should be solved.
I think you've programmed your mems / subs with pallet info too, is that right? If so that's of course the same problem, if not; then maybe you're not tagging your fixtures correctly in partial mode?
