Hi! Im new in here!
I cant find the Assign Fixtures choice in the Desk Setup menu in the Phantom Frog software. :( Have i found a bug or how should i do to assign fixtures in my shows?
Welcome :)
Firstly make sure you have the latest version of the Phantom Frog software (as well as the latest software on your desk :wink:).
If you right-click the plus and minus buttons on the phantom, click enter, then right-click the plus and minus buttons again, you reach super user.
Then if you go into desk set-up, Assign Fixtures is the second-one down. Well it is on my phantom anyway :)
sp
Bear in mind you won't see the 'Assign Fixtures' menu in Desk Setup if you have the 'Frog' desk selected. You need to select one of the desks with Wheels on.
  • 9 months later...
I still cant manage to get the superuser menu up...
I right click on + and - to make them red, then click enter, nothing happens?
I do the same, then right click again on + and - to take the red dot away, and nothing - getting confused!
Thanks
