Is there an Ooops or undo function on the FF? 8O :x
Like say......if......I hit *home* instead of *record* when in a rush.....ahem :oops:
"watching an intricate scene whip to 50/50 o/w"
Welcome, and wow, hitting home instead of the record button is quite a feat :D No there's no 'undo' function on the desk - I think this would be quite hard to implment as every user action would have to be recorded etc. Surely you'd see the fixtures go to home as you pressed it, it's normally quite easy to notice? Oh dear. Incidentally, if you don't like what your fixtures do when you home them, this can be changed with the Fixture Type Editor software.
sp
Thanks for the welcome......I didn't think there was an undo, but it never hurts to ask 8)
Also thanks for the other tip! Very useful as I'd rather see the virtual dimmer @ 0% when I home.......hummm, maybe even a diff position too. That would be cool.....home=DSC :idea:
If you want the Home function to output different values to those defined in the fixture profile data, you need to edit the fixture profile itself using the Fixture Type Editor which can be downloaded from the main Zero 88 website.
Bran Media | Myspace
