delicolor Posted Saturday at 11:40 PM Report Posted Saturday at 11:40 PM I'm taking an FLX-S into a new venue (for me) which has (or had) 48 ways of dimming, some channels of which have been modified to hard power a couple of dozen RGBW washes, brand currently unknown. I have the choice of reverse engineering the patch using my DMX-Cat (and 96 faders on the desk) or throwing caution to the wind and turning on RDM, however I am mildly paranoid about munging the settings and not readily being able to restore them afterwards. I've played with RDM in my main venue with an FLX but found it somewhat problematic, especially with flickering on cheap fixtures. Am I right to be cautious? Quote
Charlie Newman Posted Monday at 07:08 PM Report Posted Monday at 07:08 PM Hi, really depends on the kit you've got in the venue. If it would be RDM compliant then maybe go for that (I haven't had great experiences with the FLX's), but otherwise reverse engineering may be the way to go. Is there no chance of getting to the rig? Quote
delicolor Posted 16 hours ago Author Report Posted 16 hours ago On 10/20/2025 at 8:08 PM, Charlie Newman said: Hi, really depends on the kit you've got in the venue. If it would be RDM compliant then maybe go for that (I haven't had great experiences with the FLX's), but otherwise reverse engineering may be the way to go. Is there no chance of getting to the rig? There is a ladder to a high perch where I should be able to see what make/model the nearest wash is and they are probably all the same. I'll see if the tester can sniff out the RDM and failing that work it out the hard way. Thanks for your comment though! Quote
