Guest Brian M Posted February 23, 2003 Report Posted February 23, 2003 I have bought a 24/48-channel Frog for our school. The manual states that the console should be turned on "at the mains". Is there a conventional on/off switch that I can't see? At the moment students are simply unplugging the board or turning off the switch on the extension cable. Help! Thanks. :? Brian M.
K-Nine Posted February 24, 2003 Report Posted February 24, 2003 Hi, The Frog desks have an inline external power supply unit ... a black 'brick'.. with one end that plugs into the back of the desk, the other end into a normal mains socket. The easiest way to turn the desk on and off is via the switch next to the mains plug, the desk does not have its own on/off switch. Frog Reference No 5434 - Power switch on desks. K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
sjoram Posted January 26, 2005 Report Posted January 26, 2005 Personally if I don't want it off at the plug socket, I just pull the plug out of the back of the desk.
Haytech Posted January 26, 2005 Report Posted January 26, 2005 Personally if I don't want it off at the plug socket, I just pull the plug out of the back of the desk. I don´t want to panic, but there is a risk of fire, when you don´t disconnect the PSU from it´s power plug. Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
PatrickK Posted January 26, 2005 Report Posted January 26, 2005 Hi,The easiest way to turn the desk on and off is via the switch next to the mains plug... Which is all very nice in the UK, but in mainland Europe we don't have switches on outlets. An inline powerswitch or one on the desk would have been nice. :wink:
GLX Posted January 26, 2005 Report Posted January 26, 2005 The desk pulls dam all of a load, cant see how a fire would start :?:
Haytech Posted January 27, 2005 Report Posted January 27, 2005 @GLX its a question of faith in all kind of electronic stuff. I disconnect my TV,PC,Lamps etc. from mains when I leave my flat. Sebastian H. Pro - Sound Showtechnik The secret to creativity is knowing how to hide your sources. Albert Einstein "You can get a lot more done with a kind word and a gun" Al Capone
Dr Chinchilla Posted January 31, 2005 Report Posted January 31, 2005 At my school, we are instructed to make sure anything in the sound box is RCD protected (I guess for insurance cover). More than half the time, our desk is just switched on and off using the buttons on the RCD. Personally, I feel happier unplugging it, but so long as its protected, then the school don't mind
