LeeStoddart Posted February 17, 2004 Report Posted February 17, 2004 Is it possible to Tag or Untag all the channels in the Brightness section of the PW. In the Colour, Beamshape and Position sections pressing for more than a second or so on the corresponding attribute (eg Colour) button will toggle the Tag status of all the parameters. Is it possible to do the same in the Brightness section? Lee Stoddart
K-Nine Posted February 17, 2004 Report Posted February 17, 2004 Press and hold the Brightness button for approx. 1 second should tag/untag all the selected dimmer channels and fixture brightness parameters in the Program Window. K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
LeeStoddart Posted February 17, 2004 Author Report Posted February 17, 2004 Ahhh It's that key word selected isn't it! As I was writing the question I realised that on the LTP Attribute sections the change only affects the selected fixtures - so only affecting selected channels and fixtures on the Brightness section is obvious really. Lee Stoddart
K-Nine Posted February 17, 2004 Report Posted February 17, 2004 There is also a command line syntax which you can use to toggle the tagged state of one or more channels. For example, say that you have adjusted channels 1-20 and they are all currently tagged, and you want to untag channels 16-20. Enter the command: CHANNEL 16 THRU 20 BRIGHTNESS ENTER K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
