vincent2790 Posted December 15, 2005 Report Posted December 15, 2005 Hi there, since some two months we are using the new Jester 24/48 Console and besides all the usfull new features we're missing an old one we had on the Lightmaster XLS, that was parallel chasers. The XLS had two chaser faders and was able to run two chasers at the same time which was usefull in fact that you could have front- and backlights divided. We would be very pleased if Zero88 would think over a soft- / firmware solution to this thing. The Jester so far, nice thing. best regards
Kirkup_xp Posted December 15, 2005 Report Posted December 15, 2005 Using the cue stack, it is only possible to playback one chase memory at a time. However, if you program chases onto the submasters, you can play back 12(24) chases at a time. Every submaster can have its own chase, direction and attack stored. Programming and replaying chases is covered in the Jester manual. Hope this helps. Peter Peter Kirkup
vincent2790 Posted December 15, 2005 Author Report Posted December 15, 2005 Okay, then I will read into the man again. Thanks so far, i will try if this fits our needs. best regards
