ryandell Posted May 22, 2006 Report Posted May 22, 2006 I hav mastered adding fixtures naming ect but cannot get my head around the UDF's are they like generic faders or like faders that tie groups of lights into one fader like submasters, just wondering how they work It's always the easiest things I have trouble with Thanks Ryan
Kirkup_xp Posted May 22, 2006 Report Posted May 22, 2006 UDFs are User Definable Faders. You have to define what you want on them - groups, individual fixtures, channel data (submasters), override and time faders, inhibits, parameter faders, etc. Generally the syntax is <item> RECORD <UDF flash button> eg: GROUP n RECORD <UDF> - will create a Group UDF GROUP n FULL, wheel edit pan, wheel edit tilt, RECORD <UDF> - will create a channel data UDF. etc. Hope this helps Peter Peter Kirkup
ryandell Posted May 23, 2006 Author Report Posted May 23, 2006 :? so they are beaiscaly like generics, but what i want to know is how you would asign a fixture individualy, like if i had 5 fesnels how would i assign them individualy to the UDF's, Thanks Ryan (its probably all been said before) :oops:
Kirkup_xp Posted May 23, 2006 Report Posted May 23, 2006 There are several ways to assign individual fixtures to a UDF. It depends whether you want your UDF to work through the program window, or not. If you want the UDF to affect the program window, you should define a single parameter UDF. Do to this, select the fixture in question (either using the fixture number or group, then number). Now hold down SHIFT and press on the touchscreen where the DIMMER attribute is displayed. Now press RECORD, then the UDF flash button. If you want the UDF to work outside of the program window, you should define channel data to the UDF. Select the fixture and press FULL. Now set the FADE attribute to 0s for the dimmer. Next press RECORD, then the UDF flash button. I hope this helps. Peter Peter Kirkup
K-Nine Posted May 23, 2006 Report Posted May 23, 2006 The different types of UDF, how to record them, how they operate and their setup parameters are all described in the operating manual pages 109 - 116 :wink: K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
ryandell Posted May 25, 2006 Author Report Posted May 25, 2006 Hi Yes I think I have mastered the UDF's, Thanks for your help Ryan
