richard Posted May 26, 2006 Report Posted May 26, 2006 Dunno if this has been suggested before, but one thing I find very boring is having to click backwards/forwards to get to the current memory that is live on stage to edit it. This is especially annoying when I have left gaps in my memory numbers in case I add cues. What I would suggest would be that if you press and hold the 'memory' button then the next memory is set to the current memory. This would then also follow the same logic as the fact that pressing memory once jumps the cursor back to the memory number field.
K-Nine Posted May 26, 2006 Report Posted May 26, 2006 To select the Next memory for editing, copying etc you can always type the memory number in directly if you have an external keyboard attached. This is much quicker than using the cursor keys K-Nine : Technically Advanced Roving Dog In Space Bran Media | Myspace
Martin Posted June 9, 2006 Report Posted June 9, 2006 And why have gaps, you can allways use the insert function ? Move while dark! -> GOGOGO! Thank you Zero for the FR 5402
