Hello..
I have a question.
I work with a Mambo frog.
On a Mambo frog, you have SX-buttons. I tryed to program HTP under the SX-buttons, but something strange happened.
Only, if I hold down a SX-button, than only goes the intensity to 100%. If I don't hold down the SX-Button, than nothing will happen. This isn't really strange, at all.
Than I tried to progrem a few HTP under the SX-Buttons. Than I put a SX-button and switch the fader up to 50%. Than I hold down an other SX-button, the HTP starts at 50%!! How is it possible. I think that the table can only manage one HTP at time, is it right what I'm saying?
Is there anybody who can solve this problem?
I'm looking forward to read a hint or tip!
Kind regards,
Rene, the Netherlands
When you say "switch the fader up to 50%", which fader are you referring to?
The Mambo Frog has one SX Master fader which governs the maximum HTP output level of all 48 SX Buttons. Is this the fader you're referring to?
Yes, I mean that fader, the SX-master fader!
So you say that I can't manage differtent HTP levels on the SX buttons, because there is only one fader? Is this correct?
Thanks for answering...
Rene
The SX master (as with all 'master' faders) applies a scale factor to the programmed brightness level. If you have a scene with channel1 at 50% and channel 2 at full, but the SX master at 50%, the output levels will be 25% and 50% respectively.
Hope this helps
Peter Kirkup
Assuming that the SX Master (and Grand Master of course) are at full, then the HTP (fixture brightness parameters) values that are programmed into the SX buttons, either as channel data or as a transferred memory, will be output when the SX button is pressed.
Unless of course those values are currently being output at a higher value from another source elsewhere on the desk.
SX Buttons are essentially submasters without the fader.
Bran Media | Myspace
