tokm2k Posted July 12, 2006 Report Posted July 12, 2006 Hi all. Like the description says, im looking to somehow use non-dims on a fat frog. Is there a way to set a channel's dim curve to non dim, or is there a profile for one? Must be a way surely! Every other desk i know can do it lol. BTW, the racks im using are betapack ones, so can't set a channel to non dim on the rack end.. unless theres a magic function ive not discovered on my beta's! Thanks for any help.
Paul Posted July 13, 2006 Report Posted July 13, 2006 There's a couple of topics HERE and HERE which should answer your question. Basically you can't set a HTP (brightness) channel to non-dim, but there is a trick you can do by controlling the channel as an LTP channel (assigned as a fixture) and then using 2 submasters (one to turn it on and one to turn it off) with the relevant LTP attribute set to snap.
