Eh, so ive gone to a fresh memory, held in the MEM TYPE button and then i have pushed up the faders i want and then pressed program, then it came up with the next step (2) and i pushed up some other faders BUT:
1) It doesnt seem to show the steps on the cue stack (Playback)
ie
27
27.1
27.2
2)I cant see the "Shots" attribute like it says in the manual
3)if i hit finish, then start the chase (Pressing GO from the que before) it does nothing
Help?
Also how do i make a chase go automatically? as in i hit go and then it automatically plays through steps
20
20.1
What am i doing wrong?
KNine? Anyone?
Insert memories (27.1) and chase steps (27, Step 1) are different. Insert memories are used for putting a cue between 27 and 28 that will respond to a trigger (normally the GO button). Chases are a series of Step memories run in sequence.
In version 10.8 software, the chase steps won't run unless the Playback X (or Submaster fader) are above 0.
Peter Kirkup
