Lagstorm Posted June 26, 2007 Report Posted June 26, 2007 I have a small problem with frog2 and motu ultralite. Frog doesn't detect the timecode I'm sending with my ultralite smpte generator. Framerates are same in both machines. Ultralite does detect the timecode if I send it from output to input. My software version in frog is 4. Thanks for help.
Kirkup_xp Posted June 26, 2007 Report Posted June 26, 2007 Have you performed the two firmware updates in the Desk Information screen in Setup? Hold down SHIFT+CLEAR in this screen to run an update - if the update is required, the version number will appear in RED text. Peter Kirkup
Lagstorm Posted July 2, 2007 Author Report Posted July 2, 2007 Problem solved. The problem was the unupdated firmware drivers. Thanks for help.
