hey,
I want to patch more than one DMX address to a preset fader but it doesn't work. I know that it was possible on the FatFrog by pressing the insert-button in the patch-menu.
And another problem. my leap frog is working in the basic-partial mode, when I chose a preset-fader (for example for a par-can) I can't activate the same DMX address with a submaster (the right DMX address is programmed!!) until I press the clear-button. But at that time all DMX output get lost!! In the basic - full mode both preset-fader and submaster-fader are equal... did I do anything wrong??
I hope you can help me!
The behaviour you are describing of the preset faders is correct. Because the LeapFrogs work with a program window, you must clear the program window to release control of channels to the submasters or memories. You can alter this behaviour in Desk Setup/Behaviour/Preset Mix Mode... change this to HTP and you will get the behaviour you expect from Frog 1.
The multiple patches are done in Edit Fixtures - select the fixtures you wish to repatch, then click "Patch", enter the new (second) dmx address and press "Add Patch". Come out of this window, then "OK" Edit Fixtures.
Peter Kirkup
