Kresten Bager Posted August 17, 2007 Report Posted August 17, 2007 Hi all, Programming a submaster is easy if you are in the submaster window. If you are not a window appears where you can select memory or submaster and specify which one. In this window the MFKs change to a numerical keyboard. However it seems the "-" dash is missing. Thus it is not possible to type e.g. 2-4. Perhaps it is possible to make an easier way to program submasters - e.g. Press Record--> the window pops up --> press the desired submaster flash and presto a recorded submaster. Best regards Kresten Kresten Bager Polyteknisk Scenelys www.scenelys.dk
