Carl Ehrhardt Posted November 29, 2007 Report Share Posted November 29, 2007 It would be nice to select / deselect a fixture on the preset faders if i don't have to change the global flashsettings to off/select. So could I just press shift + flash button of the preset fader to select / deselect the fixture(s)? Also see here Adding Fixtures It would be easier if we control the brightness on the preset faders to chose the right one during a show. Thanks a lot. Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
Carl Ehrhardt Posted February 25, 2008 Author Report Share Posted February 25, 2008 I have found a easy way for this. if the command line is activated I can just by entering the Ch No chose the right one and then get fast access to the Colour / Beamshape without disabling the flash function on the preset faders. Quote Carl Ehrhardt Technical Director Kellerbühne St.Gallen CH-9000 St.Gallen Switzerland www.kellerbuehne.ch Link to comment Share on other sites More sharing options...
