Hi I was wondering if you've ever had that problem where say you are on memory 200 for example then suddenly it jumps to memory 1. Is there a skip button that will jump from memory to memory insted of having to press/hold the + button past empty memories.
Many thanks.
You can hold plus and minus together to change the memory number to memory 1. To quickly access any memory number it's best to plug in an external keyboard so you can type it in.
