smythy75 Posted April 11, 2009 Report Posted April 11, 2009 hey, on my desk, when i use the thmb wheel, the value takes a while to change and the fixture doesnt move, would this be a faulty thumb wheel? peter
Kirkup_xp Posted April 14, 2009 Report Posted April 14, 2009 Hi Peter It's possible that the thumb wheel sensor has come loose slightly from the wheel itself. This can be easily rectified by your Zero 88 distributor and should be covered under the warranty for the desk. If you have no joy with your distributor, please let us know and we can arrange repair here. Kind Regards, Peter Peter Kirkup
smythy75 Posted April 15, 2009 Author Report Posted April 15, 2009 thanks peter! i will have a look at it and try and get it to the distributor! my prob is its the only desk we have and its used sunday, wednesday, fri!
joe bleasdale Posted June 1, 2009 Report Posted June 1, 2009 Peter, Is it also a software thing..? I often find that I roll the wheel far to far for things like intensity. Then when I try to bring them back up, it takes a while. When I put them down slowly, they act as normal. I am thinking that the software is not acting properly.... Regards,
Paul Posted June 2, 2009 Report Posted June 2, 2009 If the wheel edit mode is anything other than Absolute, then with multiple fixtures selected, the desk will allow you to roll the wheels below 0% and above 100%. The desk allows this to maintain the relative levels of the different fixtures selected. So if you roll a wheel 3 revolutions below zero for example, you'll have to roll it back up 3 revolutions to bring it back to zero before you'll see any output change. So it can look like the wheels stop responding for a time. There will be a change in the next version of software (reference JES-2072) to improve this behaviour, as it can be confusing as you've found.
