pierotec Posted April 29, 2009 Report Posted April 29, 2009 Hello, you can improve the quality of video2 why do not see any new features graphics of new firmware on the video2 (example: colour picker or colour scheme orb) Ciao piero
Kirkup_xp Posted April 30, 2009 Report Posted April 30, 2009 Hi Piero Unfortunately on the original hardware design for Frog 2, the second monitor is generated by a different processor to the first monitor. Therefore, it cannot support the advanced graphics which are supported on the other monitors. Newer Frog 2s are being built with a different mother board which supports these graphics on both monitors. We do have an upgrade kit available so that existing users can upgrade if they wish - please contact your Zero 88 distributor for pricing and information. I hope this helps, Kind Regards, Peter Kirkup
pierotec Posted May 1, 2009 Author Report Posted May 1, 2009 Hi Peter, I wanted to know if have been improved others functionality on new frog2 with new hardware. Hello piero
Kirkup_xp Posted May 1, 2009 Report Posted May 1, 2009 Hi Piero The new motherboard is the same one used in Leap Frog 48/96 and Orb, and is fitted with a higher spec processor module (as used in Orb). On the new hardware, Monitor2 has the same graphics capabilities as Monitor1. I hope this helps, Peter Peter Kirkup
pierotec Posted May 1, 2009 Author Report Posted May 1, 2009 Thank you, would therefore be possible to upgrade the old hardware with the new?. Or this is not recommended because doing so would be complex, or because it would cost much hight. ciao piero
Kirkup_xp Posted May 1, 2009 Report Posted May 1, 2009 The upgrade kit is basically a new base tray for the desk with a complete new set of processor boards. It needs to be fitted by a relatively skilled technician, if you prefer you can return the desk to one of our dealers or direct to us to have the kit fitted. Contact your dealer or Keith (krogers@zero88.com) for pricing. Peter Kirkup
