Billy Posted May 2, 2009 Report Posted May 2, 2009 when working with memories, how do you make moving heads move on dark between cues? Quote
Carwyn Posted May 2, 2009 Report Posted May 2, 2009 you need to go in to set up and theres a setting in there to turn move on dark on or off you will need to select on what you might find is after turning on move on dark you will need to run through the q stack once before the move on dark fully functions talk soon Quote
