mbrenkley Posted August 1, 2009 Report Posted August 1, 2009 Hi guys, Just programmed an edinburgh preview show on a Jester TLxtra and i'm just making sure that its all the same software and I can use the show on a normal Jester 12/24 when in edinburgh. Thanks
Paul Posted August 4, 2009 Report Posted August 4, 2009 The showfile format used on the JesterML and JesterTL desks is different to the basic Jesters, so you can't cross-load shows. For pre-programming shows without the actual desk it's best to use Phantom Jester. If you've already programmed the show on the wrong desk, you could snapshot the memories one by one using the DMX Input.
mbrenkley Posted August 4, 2009 Author Report Posted August 4, 2009 Thanks. I've just reprogrammed it. It may be worth putting something in the literature stating that cross loading is not possible.
