mingen Posted February 8, 2010 Report Posted February 8, 2010 Hey all together, i hope someboby can help me. I have the following Problem : My Fixture has on the last DMX Channel two Parameters. Range 0%-50% is the Strobe from Fast to Slow and Range 51%-100% is the Dimmer. So now i want to splitt this Parameters in the Fixture Editor I hope you understand and can help me. Thanks to all and greetings from Germany. Stefan
Laubfrosch Posted February 17, 2010 Report Posted February 17, 2010 Hi Stefan, there is no function of a DMX-Channel-Level-Split. Probably this is a work around. Quote "Virtual Intensity Each fixture can have a Virtual Intensity channel. This channel is not assigned to a DMX address, but can be used to scale the output of other channels, creating an effective dimmer for colour mixing fixtures which do not have a separate dimmer. An example of the use of a virtual intensity parameter would be an LED colour mixing fixture which has just 3 channels – Red, Green and Blue. By scaling these channels on a virtual master, you can dim a mixed colour. Zero 88 Fixture Editor User Guide - IM8554 Issue 2 - August 2008 - Page 6 of 10 First create the Virtual Intensity channel as a normal parameter, but tick the “Virtual Channel” box. Then select “Scale By Virtual Intensity” on the relevant fixture parameters." You may do so with strobe/dim channel of your fixture I hope this is of help. Cheers Sven Sven Paulsen Klangfarbe Vienna
