chw Posted March 9, 2011 Report Posted March 9, 2011 Hi, Is there a way to keep the effect parameters separate? My Idea is to modify the speed of effects by using a sub-master fader. Unfortunately the size is also modified. Besides that I have some problems with the effects window - sometimes it is not possible to open the functions menu (sine, step, ramp etc.) by pressing enter on the desk or an external keyboard. The + and - keys are working. After saving the effect to a mfk everything works - after a reboot the function in the effects windows is "empty" the desk shows something like E40(). The effect is not working, the only way is to reprogram it. That is very annoying, especially as submasters are effected as well. Has someone a solution or a work around? The OS version is 6.1 Thanks. regards Christian
Kirkup_xp Posted March 10, 2011 Report Posted March 10, 2011 Hi Christian There are plans to add a feature like this in a future software release, however at the moment all effects parameters are stored together. Can you upload a show file with the 'bad' effect in it so we can take a look at what might be missing? thanks, Peter Peter Kirkup
