Is there a 3D software programme compatible with the Jester where we could create our show on a PC screen by mimicking our fixtures and positions in a 3D view complete with the correct footprint size of our show?
ie back truss and front truss and same spacings of fixtures etc?
http://www.thedustytools.com/13.html
Scroll to the bottom to see our set up.
Hi There BassTool,
There are a number of 3D simulation software packages out there - most of them offer a DMX Input box which you can feed the DMX Output from your Jester ML24 into, to mimic the behaviour of the lights on stage. If those packages don't support a DMX Input box, you can use a DMX-Ethernet box (like our 1 Universe Ethernet Box) to convert the physical DMX into Ethernet signals, which the simulation software can then use to determine the look on stage.
Check out:
www.cast-soft.com
www.capturesweden.com
I hope this helps,
Peter
Peter Kirkup
Hi There BassTool,
Check out:
www.cast-soft.com
I hope this helps,
Peter
Thanks for that Peter! ;)
