Dan West Posted December 17, 2012 Report Posted December 17, 2012 Received a Solution Desk today! The trusty Fat Frog was too small for us ;(. Anyhow, Put a few lights onto the desk, moving heads, led parcans and for some reason the LED parcans are working in reverse. Say i output the desk at 100% on RGB the fixture goes off. If I set the output to 0% the lights come on at 100%. Had a look in the manual if fixtures can be reversed but apart from pan/tilt theres nothing. Is this an issue with the desk? Cheers Dan Quote
Dan West Posted December 17, 2012 Author Report Posted December 17, 2012 Don't worry, I have solved the issue. It was relating to Positive/Negative RGB in the fixture profile. Just created another profile with the polarity being the other way. Quote
