Holger
Everything posted by Holger
  1. I starterd the ZerOS-7.11.exe on my PC, USB stick was formatted and files were copied to it. Everything seems to be fine in the process. Then I plugged off the FLX S24, entered the USB stick at the back ("behind" the touch panel) and plugged in the board. It started, but there was no new version installed. Attached you will find the system info of the board. What can I do? What is wrong?
  2. Thanks a lot! Yes, when I tap "Effects" I can select a plaette. And it seems to work in my test case. I will try to use it in more details - and I suppose I'll have further questions.... Thanks a lot so far!!
  3. Thanks, I tried the first suggestion on Phantom but failed: 1) I selected my scene (Channels 1 and 2 100%) -> A01_SelectScene.jpg 2) Then I hold shift and clicked Record -> A02_AfterShiftHoldAndRecord.jpg (In real the not illuminated playbacks are blinking) and A02_TouchScreen.jpg Now, you see the touchpad - how can I select an empty palette in the touchscreen?
  4. We have the FLX S24. I am a beginner, worked through the manual....This message didn't send. To make an easy show we want to setup 5 different mood lighting (or scenes or whatever it is called). I am programming a master playback. Each scene should be used several times, e.g. scene 1 in cue 10, 15, 27 and 30. Now, my question is how can I do that in a way that when I have to change the scene 1 it is changed in all cues (10, 15, 27 and 30)?
